Volkswagen
( Volkswagen Bora ) Vag Com fault codes Pomoc
   Forum VOLKSWAGEN Forum Strona Główna -> ( Volkswagen Bora ) Porady, problemy techniczne
krzysiek991
Posiadane auto: Volkswagen Bora 1.6
Wysłany: Sro 07 Lut 2018, 22:40
Może mi ktos pomóc rozkodowac co tam pisze? jakie błedy są i jak naprawić?
VCDS-Lite Version: Release 1.2
Saturday, 03 February 2018, 14:52:27:0
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine Labels: 06A-906-033-APF.LBL
Controller: 06A 906 033
Component: SIMOS33 1,6l 2VG00HS3087
Coding: 00031
Shop #: WSC 01317
VCID: DCCB97735F33
3 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 35-00 - -
18058 - Shareware Version. To Decode all DTCs
P1650 - 35-10 - Please Register/Activate - Intermittent
17526 - Shareware Version. To Decode all DTCs
P1118 - 35-00 - Please Register/Activate
Readiness: 1100 1101
Address 03: ABS Brakes Labels: None
Controller: 1C0 907 379
Component: ESP 20 CAN V002
Coding: 10241
Shop #: WSC 01317
VCID: E7A1B89F9675
3 Faults Found:
01044 - Control Module Incorrectly Coded
35-10 - - - Intermittent
01542 - Yaw Rate Sensor (G202)
57-10 - Electric Circuit Failure - Intermittent
00812 - Brake Pressure Release Solenoid (F84)
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0003
Coding: 12338
Shop #: WSC 01317
VCID: 351DA2D71C59
3 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.LBL
Controller: 1J0 920 802 B
Component: KOMBI+WEGFAHRS. BOO V15
Coding: 01343
Shop #: WSC 00000
VCID: 2237698BBDD7
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1017265
No fault code found.
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
VCID: F093D3C3A3BB
Address 35: Centr. Locks Labels: 1C0-962-258-II.LBL
Controller: 1C0 962 258 J
Component: 01 Zentr.Verriegel. 0002
Coding: 04097
Shop #: WSC 01317
VCID: 2E2F8DBBF90F
poduzki
Saturday, 03 February 2018, 14:53:33:0
Control Module Part Number: 6Q0 909 605 A
Component and/or Version: 02 AIRBAG VW5 0003
Software Coding: 12338
Work Shop Code: WSC 01317
VCID: 351DA2D71C59
3 Faults Found:
   Forum VOLKSWAGEN Forum Strona Główna -> ( Volkswagen Bora ) Porady, problemy techniczne Wszystkie czasy w strefie EET (Europa)
Ogłoszenia sprzedaży - Volkswagen Bora »
Opinie o samochodach Volkswagen Bora - testy użytkowników »
Popularne dyskusje w dziale: ( Volkswagen Bora ) Porady, problemy techniczne
VolkswagenPolo
13 990
162 000 km
VolkswagenGolf
26 900
213 000 km
VolkswagenPassat
38 800
270 000 km
VolkswagenScirocco
27 900
186 249 km
VolkswagenTransporter
121 900
109 000 km
